Home | Download/Install | Documentation | Packages | Screenshots | News | Forum/Mailing-lists | Contact | GForge
Differences
Link to this comparison view
packages:vplants:lpy:doc:install [2009/07/23 11:29]
admin
packages:vplants:lpy:doc:install [2016/08/22 13:19] (current)
admin [Installing Lpy]
Line 29: Line 29:
 You should first install all dependencies. You should first install all dependencies.
 +You should then retrieve the sources from https://github.com/openalea/lpy.
 Then in a shell, go in the project home directory and simply type Then in a shell, go in the project home directory and simply type
 <code bash> <code bash>
packages/vplants/lpy/doc/install.txt · Last modified: 2016/08/22 13:19 by admin   Back to top
INRIA   INRA     CIRAD     AGROPOLIS IBC
INRIA GForge RSS feed Valid XHTML 1.0 Valid CSS Driven by DokuWiki
